Advies om de zekeringkast te vervangen - oud huis
19 feb 2021
Fuse box replacement, I am trying to replace my fuse boxes to make it pass inspection. my connection is 3X400 + N - AC,
1. Not sure which differential to use 4P or 2P
2.in the outgoing fuse box i can see your switches connected to one circuit, can anyone please help me understand that.
3. I have 2 fuse boxes, photo attached.
4. Can someone suggest a contractor who can replace these in Zaventem. I have tried reaching out to 2-3 contractors and none of them are responding.
Appreciate any advice I can follow.
    187,3 KB · Weergaven: 11
    181,3 KB · Weergaven: 11
    195,8 KB · Weergaven: 12
for 4X400V + N u use a 4P Diff.
Further i suggest u renew everything.
Take a look with someone with electrical knowledge to determ what is needed
Probably to pass inspection you need to renew other things beside the fuse box.. Best is to contact a constructor, close to Zaventem i know www.vewotec.be
Subject
Comments
